2014 Honda Vezel - P0171 - Old Habits & New Tech
Good Habits Can Become Bad Habits When the Technology Changes
That is the main lesson I took from a recent issue with my 2014 Honda Vezel Hybrid. This is not written as a mechanic’s guide, because I am not a mechanic. I would consider myself a very light enthusiast at best. I drive, I observe, I expect a certain level of performance from the vehicle, and I try to understand enough to avoid being completely blind when something goes wrong.
In this case, the problem started as what looked like a typical lean condition. The vehicle was throwing a P0171 fuel system too lean code. When the engine fault came up, other check lights would also appear, and some features such as incline assist would not behave normally. The move-off from a stop also became poor at times.
Because it was a lean code, the natural direction was to look for air-related issues first. That is not an unreasonable path. A lean code often points people toward vacuum leaks, intake leaks, MAF sensor issues, MAP sensor issues, PCV problems, EGR problems, or some kind of air/fuel metering mismatch.
The problem is that the actual cause does not always follow the most obvious path.
The old habit
For years, I had a habit of using injector cleaners and fuel treatments. I would see something on the shelf, buy it, and throw it in the tank. On my previous vehicle, a 2004 Honda CR-V (and all older vehicles I’ve had), that never seemed to cause any noticeable issue. Older systems generally felt more forgiving, and the habit seemed harmless.
I carried that same habit over to the 2014 Vezel.
Looking back, that may not have been wise.
I cannot prove the cleaners caused the problem, but my habit of using random off-the-shelf fuel treatments may have contributed, masked symptoms, or delayed finding the real issue.
That is an important distinction. I am not saying every fuel treatment is bad. I am also not saying a specific bottle destroyed anything. What I am saying is that newer engines, especially direct-injection and hybrid systems with tighter monitoring, may not tolerate casual maintenance habits the same way older vehicles did.
The symptoms
The main code was:
P0171 - Fuel System Too Lean
Using my scan tool, I monitored fuel trim values while driving and idling. My scanner displays fuel trim in a ratio-like format where 1.00 is normal. So a reading of 1.30 means the ECU is adding roughly 30% fuel correction.
At first, the short-term fuel trim was often in the 1.20x range, with highs around 1.30. As the issue progressed, things got worse. Eventually, 1.30 to 1.31 became the normal reading at startup and while driving. At times, I saw short-term trim climb as high as around 1.45.
That progression mattered.
It was no longer an occasional correction. The vehicle was consistently trying to add a lot of fuel.
At the same time, the vehicle sometimes felt better after cleaning or replacing certain parts. Acceleration improved at points. Power felt better at times. But the fuel trims did not truly return to normal.
That is where the diagnosis became tricky. The vehicle could feel better, but the scan tool was still showing that the engine management system was not happy.
What I checked and replaced
Because the code was lean, the first direction was the air/fuel metering side.
Over the course of the diagnosis, several things were checked, cleaned, or replaced:
  • Air filter
  • O2 / air-fuel sensor
  • MAF sensor
  • EGR valve
  • Spark plugs
  • Intake/EGR-related cleaning
  • Fuel-system cleaner
Some of those steps produced improvement. The EGR valve, for example, was filthy, and after cleaning/replacement there was some improvement in behaviour. But the improvement was not enough. The fuel trim remained too high, and the check lights kept returning.
The spark plugs also looked bad when removed. All four were similarly fouled. That made them suspicious, but after replacing them, the short-term fuel trim was still poor. So the plugs may have been part of the symptom, but they were not the full answer.
The fuel additive lesson
One of the more frustrating parts of this process was checking fuel cleaners locally.
Many products simply say things like:
  • Fuel injector cleaner
  • Gas treatment
  • Complete fuel system cleaner
  • Octane booster
  • Upper cylinder lubricant
But the active ingredients are often not printed clearly on the bottle.
That matters.
Not every “injector cleaner” is the same. Some are basic solvents. Some are fuel treatments. Some are octane products. Some are mainly lubricants. For newer engines and stubborn fuel-system deposits, the ingredient often discussed is PEA, or polyetheramine.
Because the bottles did not give enough information, I used web searches and AI-assisted searches to check SDS documents and product information. That helped narrow down which products locally were likely to be proper fuel-system cleaners and which ones were just generic treatments.
The product I eventually tried was AMSOIL Gasoline P.i. Performance Improver. It was one of the few locally available products that seemed to fit the stronger cleaner category.
It did not solve the problem by itself.
That does not mean it was useless. It simply means the issue had already reached the point where a tank additive was not enough, or the root cause required direct service.
What finally changed the result
The final major step was professional injector cleaning.
I do not have the full bench report, so I cannot say whether the numbers I was given were per injector, an average, or based on a specific machine test cycle. What I was told by the shop was that the injectors were flowing around 8 ml before cleaning and improved to around 10 ml after cleaning.
I am not treating those numbers as a factory specification. I am treating them as a rough before-and-after indicator.
The more important result was what happened afterward.
For the next two days:
  • No check lights returned.
  • Fuel trim stayed within range.
  • The vehicle drove better.
That was the first time in the diagnostic process where the scan tool and the driving behaviour both agreed that things were better.
The scan tool lesson
I strongly recommend that vehicle owners consider owning a scan tool.
A scan tool does not make you a mechanic, but it can stop you from driving blind.
You do not necessarily need a $500+ professional tablet scanner. Some brands, such as Launch, sell lower-cost manufacturer-specific tools. Mine is a Honda-specific scan tool. It can diagnose general OBD functions on many vehicles, but it has deeper functions for Honda.
For someone with only one or two vehicle brands in the household, that may make more sense than buying a large universal professional unit. If you have several different vehicle brands, then a broader scan tool may be more practical.
The important point is this: without live data, I would have been relying only on warning lights and how the vehicle felt. The scan tool showed that even when performance improved, the fuel trim was still wrong.
That prevented me from assuming the problem was fixed too early.
The shop inspection lesson
There is no blame to throw around here.
I am not a mechanic. I do not keep up with every technology change in the automotive world. I drive, I observe, I maintain what I know to maintain, and I expect certain performance levels from the vehicle.
Mechanics and shops are also not mind readers. Some shops will do a general inspection as part of servicing. Some will only do exactly what was requested. Some basic checks may be considered the owner’s responsibility unless specifically asked for.
So my view is simple: if you want a proper overall inspection, request it clearly and be prepared to pay for it if it is additional work.
A regular oil change does not automatically mean every filter, hose, fluid, plug, tyre, sensor, and system was inspected. If you want those things checked, say so.
Also, if you do not use the same shop every time, do not assume each mechanic has the full history of the vehicle. Even if one shop keeps good records, another shop may not have access to them.
Maintenance habits I am taking more seriously now
This experience changed how I think about maintenance.
Some things are boring, but they prevent expensive problems later.
Here are the habits I would suggest other owners consider:
  • Do oil changes at or before the recommended interval.
  • Replace the air filter regularly. In dusty conditions or heavy use, replacing it with each oil change may be cheap insurance.
  • Replace the cabin filter regularly as well.
  • Use the correct spark plugs, not just plugs that physically fit.
  • Check the spark plug interval. Even if the manufacturer says 100,000 km, a more conservative interval may make sense for high-use vehicles.
  • Verify the transmission service interval and use the correct fluid.
  • If the vehicle has a DCT or hybrid transmission system, check whether there are secondary fluids or related services that should be done together.
  • Do not ignore coolant. Coolant is not just coloured water. It affects corrosion protection, heat transfer, water-pump life, seals, and long-term cooling-system health.
  • Check brake fluid and other service fluids based on age and condition, not only mileage.
  • Replace wiper blades before they become useless. Visibility is safety.
  • Check tyre/tire pressure at least monthly.
  • Check tyre condition, alignment, and suspension wear.
  • Do not assume every shop checked every basic item unless it was requested or listed.
  • Be careful with random off-the-shelf fuel additives.
  • When labels do not show active ingredients, check the SDS or product sheet online.
  • If dealer or manufacturer support is available, ask questions.
  • If not, use forums, blogs, service manuals, web searches, and AI-assisted research to narrow things down.
  • Keep a maintenance log. Record dates, mileage, parts, fluids, brands, shops, costs, and notes. Not everyone uses the same shop every time, and not every shop keeps detailed records. A log helps you and the mechanic see what was already done and what may be related.
I am deliberately not putting specific time or mileage intervals beside every service item, because those vary by vehicle, usage, oil type, driving conditions, and manufacturer guidance.
Someone who drives mainly to and from an office each day may only reach their oil-change mileage once per year. A salesperson, field technician, delivery driver, or anyone doing heavy daily mileage may reach the same interval every three to six months, or even sooner. The use of full synthetic oil, conventional oil, or synthetic blend can also affect the recommended interval.
Some items are mileage-based. Some are time-based. Some break down from age, heat, moisture, or lack of use even when the mileage is low. That is why it is best to follow the maintenance guide for your specific vehicle and get advice from a mechanic who understands that vehicle and how it is being used.
The value of records
I have been keeping vehicle records for years.
Before using an app, I kept a small pocket-sized notebook in the glove box. When I sold a vehicle, the books went with it. After moving digital, I would export or email the service log where needed.
For this issue, I was using aCar and could export my records. That helped me check dates, mileage, parts, and service history.
It also reminded me that correlation is not causation.
Just because something was replaced before a symptom changed does not mean that part was the cause. Just because performance improved after one step does not mean the root problem was solved.
Even with my own checks, scan-tool readings, web searches, and AI-assisted research, the injectors were not the main focus until a mechanic with relevant experience raised the possibility.
That is a lesson by itself.
Tools help narrow the search, but experience still matters.
Good records do not diagnose the vehicle by themselves, but they help build the timeline. The timeline helps you, your mechanic, and even the next owner.
Final takeaway
The biggest lesson from this issue is not “never use fuel cleaner.”
The lesson is:
Do not carry over old maintenance habits blindly.
What worked fine on an older engine may not be appropriate for a newer one. Older systems may be more forgiving. Newer engines may monitor more closely, react more quickly, and expose problems in ways that older vehicles did not.
In my case, a lean code led me through air filters, sensors, EGR, spark plugs, fuel treatments, and a lot of scan-tool monitoring before the injectors were professionally cleaned.
It was costly, partly because the early steps were logical but not the final cause.
I am sharing this because someone else may save time and money by remembering one simple thing:
Good habits can become bad habits when the technology changes.
As a notation - the knowledge and fix was provided by:
RPM Auto Repairs
Montego Bay Rose Hall
876-571-9288
The injector cleaning was done by:
Lizard Automotive Works & Services
24 Caledonia Rd, Mandeville
876-665-5297
