When Old Knowledge Still Matters: COM Ports, Resource Allocation and Troubleshooting
One of the things I continue to advocate for in IT is the importance of core competencies.
Technology changes constantly. Some of the things we learned years ago are rarely touched today, and some are effectively obsolete.
But the concepts behind them often remain useful.
I recently encountered a good example of this while troubleshooting a laboratory chemistry analyser connected to a newly configured Windows computer.
The software was installed and opened normally, but it would not communicate with the analyser.
An older computer was still available, and the analyser communicated with that system without a problem. That gave us something important immediately:
The analyser itself, the basic connection and the software/hardware combination were known to work.
The newer computer was using a USB-to-serial adapter to communicate with the equipment. Windows detected the adapter correctly and there were no obvious hardware errors in Device Manager.
So why wouldn’t it communicate?
Sometimes the old knowledge comes back
Anyone who worked on PCs years ago may remember manually configuring hardware resources.
Depending on the era, that could involve:
  • COM ports;
  • LPT ports;
  • IRQs;
  • I/O addresses;
  • DMA channels;
  • jumpers;
  • DIP switches;
  • BIOS settings.
You couldn’t always just install a device and expect the operating system to sort everything out.
Sometimes you physically changed jumpers on a card.
Sometimes you changed a row of DIP switches.
Sometimes you had to make sure two devices were not trying to use the same resource.
While thinking about this particular problem, one number unexpectedly came back to me:
378
That was the traditional base I/O address associated with LPT1.
Thinking a little further about resource allocation brought back another familiar example:
3F8
Traditionally associated with COM1.
For those who worked with this type of hardware, here’s an expanded list:
  • 0x378 — traditionally associated with LPT1
  • 0x3F8 — traditionally associated with COM1
  • 0x2F8 — traditionally associated with COM2
  • 0x3E8 — commonly associated with COM3
There was a time when seeing 378 could immediately make you think parallel port.
Seeing 3F8 could make you think COM1.
I certainly don’t remember all of the old addresses anymore. I hadn’t needed to think about most of them in years.
And honestly, there is very little reason to memorise them today.
The important part isn’t remembering the numbers.
It is remembering why those numbers mattered.
Hardware needed resources
Older PC hardware often required specific resources to operate.
Two devices couldn’t simply claim the same exclusive resource and expect everything to work.
That forced technicians to develop a particular way of thinking.
You didn’t only ask:
Is the device connected?
You also asked:
What resources is it using?
What is the software expecting?
Is something else already using that resource?
Does the working system have a different configuration?
That mindset is still useful even though the technology underneath it has changed considerably.
Modern COM ports are not quite the same thing
Modern systems have abstracted much of this away.
If I connect a USB-to-serial adapter today and Windows calls it COM3, that does not necessarily mean there is a traditional UART sitting at the old COM3 I/O address.
The relationship is more like:
USB device → USB controller → driver → serial interface → COM port number → application
The operating system and driver handle most of the ugly details underneath.
The COM number remains partly because applications — particularly older and specialised applications — still understand the concept of a serial port.
So we have essentially retained a familiar interface even though the underlying hardware may be completely different.
That is an important distinction.
USB itself wasn’t the problem
This also isn’t quite the same thing as plugging several devices into a USB hub.
USB is specifically designed so that multiple devices can share the bus.
The issue here wasn’t:
Two USB devices are connected, therefore they are conflicting.
Windows was quite happy with the USB-to-serial adapter.
The driver was working.
The adapter was detected.
The problem existed at another layer.
The laboratory software expected the analyser to be available on COM1.
On the newly configured computer, another device had already been assigned COM1.
The USB-to-serial adapter connected to the analyser had been assigned COM3.
From Windows’ perspective, everything was fine.
From the application’s perspective, the analyser wasn’t where it was expected to be.
The fix
The existing device using COM1 was reassigned to COM5.
That freed COM1.
The USB-to-serial adapter connected to the analyser was then changed from COM3 to COM1.
Communication was immediately established.
No software reinstall.
No hardware replacement.
No special knowledge of the chemistry analyser itself was required to identify the underlying problem.
The important question was simply:
What communication resource does the software expect, and what resource has Windows actually assigned to the device?
This is why fundamentals matter
I don’t think a new technician needs to memorise that COM1 traditionally used 0x3F8.
There is very little reason to memorise old IRQ tables, DMA channels or jumper combinations today either.
I don’t remember most of them myself.
What I do think is important is understanding that these things existed and why they existed.
That knowledge creates a mental model.
A technician who understands resource allocation may look at a USB serial communication problem differently from someone whose experience has mostly been:
Plug USB device in → Windows detects it → device should work.
Both approaches make sense based on the technology each person has worked with.
But specialised and legacy equipment doesn’t always follow the expectations we have developed from modern consumer hardware.
Laboratory equipment is only one example.
The same thing can appear with:
  • industrial equipment;
  • CNC machines;
  • POS systems;
  • telecommunications equipment;
  • UPS management interfaces;
  • scientific instruments;
  • building-control systems;
  • older printers;
  • security equipment;
  • embedded systems.
Some of this equipment can remain operational for decades.
The PC attached to it may be replaced several times while the actual machine continues doing exactly what it has always done.
Eventually, modern and legacy technology have to meet somewhere.
You don’t have to know the equipment
This is also why I place so much value on broad technical foundations.
You may not know the particular application.
You may never have seen the particular piece of equipment.
You may have no idea what a chemistry analyser actually does internally.
But you can still ask:
  • How does it communicate?
  • What sits between the software and the hardware?
  • What does the working system do differently?
  • What resources are being assigned?
  • What does the application expect?
  • At what point in the communication path is it failing?
Once you understand the layers, unfamiliar equipment becomes much less intimidating.
Learn, forget, remember, relearn
Technology moves on.
Some knowledge becomes obsolete.
Some gets forgotten simply because we stop using it.
That happened to me here.
I wasn’t sitting around remembering old serial and parallel port addresses. It was only when I started thinking about resource allocation again that 378 suddenly came back to me.
Then other pieces started falling into place.
And if I needed the rest?
I’d look them up.
That’s perfectly fine.
The value isn’t being able to recite a table from thirty years ago.
The value is knowing what to look for and why it might matter.
Google, documentation, forums, AI and other resources can provide an enormous amount of information.
But your foundation influences the questions you ask those resources.
That is one of the reasons I continue to advocate for core competencies.
Learn the current technology, but understand the foundations beneath it.
You may never configure a jumper or DIP switch again.
You may never manually assign an IRQ.
You may never need to remember what 0x378 means.
But one day you may connect a modern USB adapter to an old piece of specialised equipment and discover that the lesson behind all of that old knowledge is still very much alive.
